"Cat" pans
Anyone have a picture of a starboard cat style oil pan pan. I am talking about the style of pans where the kickout goes toward the center of boat. I am trying to see how the kickout area is handled where the oil filter goes. Thanks
With a kick-out style pan on the port side of a BBC, you will need to use an adaptor and route oil lines to a remote mounted oil filter. Even with a std pan, the filter is difficult to access if it is mounted on the block.
2 Attachment(s)
Originally Posted by BenPerfected
(Post 2910894)
unless you are spinning the engine baclwards or driving in a specific circle, can't see why you would want a kick out on that side...the purpose is to get the oil away from the crank and making H/P...Rob
Originally Posted by ezstriper
(Post 2911311)
Ok, never knew they were that close....
Thanks for the pic, exactly what I needed to see. Engine builder is concerned about having the kickout on the "wrong" side of the engine. Concerned about how well the pan will work as far as oil control. Any thoughts?
Originally Posted by bck
(Post 2912526)
Do you have a pic of the inside of the pan in the left picture?
(Post 2913139)
| All times are GMT -5. The time now is 05:15 AM. |
