-   -   RPM's? (https://www.offshoreonly.com/forums/general-q/213267-rpms.html)
footchopper 07-19-2009 11:24 PM
RPM's?
How many RPM's should I be turning on my 7.4 (carb'd) Bravo 3. Formula 252, currently runs 54 on GPS @ 4300.
Griff 07-20-2009 01:44 AM
It should have the WOT operating range right on top of the engine. I think its 4400-4800 or so, maybe 4200-4600???
Spin it as close to the top WOT # range as possible to make the most power.
Boat Tech 07-20-2009 02:18 AM
The mercruiser service manual said your rpm range is 4200-4600 rpms. And also if you still have the stock flame arrestor it might tell you what the max rpm would be.
footchopper 07-20-2009 11:46 AM
footchopper 07-27-2009 09:33 PM
New Plugs!!!!!!!!!!!
Today I went and changed my spark plugs to the factory recommended AC Delco plugs. I also changed out impeller assembly. Now I was running WOT @ 4950 RPM's !!!!!!!!! Must have had a bad NGK plug. Not sure, but it runs awesome now.:evilb:
