Originally Posted by PURPLE HORNET
(Post 2917458)
PLEASE ANSWER THIS QUESTION FOR ME. When you brought the pistons back to the machine shop and told them to hone them out what was their reply ??
Some people may have done this but I have never reused a piston that had to be pressed on and off a rod more thn once.
Now you are saying you took a couple of well used pistons and removed them from a pressed fit rod. Then the piston was honed and the rod was pressed back in. Pressed or heated either way that it was done I would throw the pistons in the trash. Once again think about how much fun pulling that engine was. |
(Post 2917909)
With the proper fixture, this procedure puts absolutely no stress on the piston. That being said, my experience has been that once they start to tighten up in the piston, they are junk about half of the time. |
Originally Posted by BillK
(Post 2917983)
ph,
With the proper fixture, this procedure puts absolutely no stress on the piston. That being said, my experience has been that once they start to tighten up in the piston, they are junk about half of the time. The trash can is the only good place for these pistons at this time. I am no joe motor head but I have leaned threw experience. He will be pulling this engine again if these pistons are used. |
| All times are GMT -5. The time now is 12:41 PM. |
