no water to pump
hooked ears to outdrive turned on water started motor promptly fried brand new impeller removed inlet hose to pump turned on water at outdrive but no water comes out of hose ? can reverse water flow and get water to flow out of outdrive HELP!!!! 502 with bravo 1
Do you have a flushing kit in the boat? I assume not because you use the muffs but just thought I would ask. If you do then check the valve on it. Mine stuck one year and it did the same thing.
heck I never use muffs anymore and not without a spotter
they always seem to fall off when I climb in the boat to start it :) |
I have a low water intake Bravo 1 with a 454 and with mercruiser muffs and the elastic band too much waterleaks and I cant draw anything.
I remove the pipe to the pump and put the hose on the pump and its all OK? Is this normal (I have used muffs and lots of tape ok in the past) |
Originally Posted by Beeman
(Post 2918249)
OH there is a plastic insert to hold the rubber hose in the transom assbly. Remove the hose barb, pry out the insert, scrape/enlarge the hole/RTV and reinstall a new insert and the hose barb.
| All times are GMT -5. The time now is 03:53 PM. |
