OIL Pressure Going UP ^^^^^ ??????
I was running my boat for the first time this year this past weekend. Down the river oil Pressure on port engine ran around 60PSI Normal for my Boat. Back up the river the Oil Pressure got up to 80 PSI. What makes oil pressure go up.??? I would be more concerned with LOW oil pressure. Is high pressure a concern. Have not run the boat again to see if it still runs high.
Thanks for any input, |
Originally Posted by cocktails
(Post 2920883)
Were you running the same RPM? Was the oil temp the same? Colder oil will make more PSI. As will more RPM.
| All times are GMT -5. The time now is 07:48 AM. |
