No reading from Gaffrig GPS speedometer
I have a Gaffrig Performance GPS Speedometer that stopped giving me a reading last year. The red light that goes out when the antenna has found a satelite did not go out. Reading the other thread on here I came to the conclusion that the battery in the antenna needed to be replaced. I have since replaced it and now after a few seconds the red light goes out but I still do not get a reading on the speedometer. Any suggestions? My unit does not do the sweep and go to the 9:00 position as suggested in the thread. It does say Gaffrig Performance on the guage. I don't know if this is one that Livorsi built or not. Do I need to hook the red wire up to the battery for 48 hours to charge the unit like I had to with the initial install?
It is not a Livorsi guage. Livorsi built ones say "Gaffrig Precision Instruments" on the guage face.
Originally Posted by Sledge Hammer
(Post 2922442)
No one out there had the issue and resolved it?
Well, I had a call in to Livorsi and they called me back and said I would have to send it in. I said I saw on the net that people changed their battery and he said you have to send it in because it needs to be reprogrammed. Then I told him it says Gaffrig Performance and as Griff pointed out, he said it is not a Livorsi Guage and I should follow up with them. I did have an email out to Gaffrig as their tech assistance by phone is only up until 12:00 pm. They gave out an email address for assistance and they responded saying:
"YOU PROBABLY WOULD NEED TO BUY A NEW RECEIVER/ANTENNA OUR PART# 9251, WHICH YOU COULD ORDER FROM OUR WEB-SITE AT WWW.GAFFRIGPERFORMANCE.COM OR IF YOU WOULD LIKE TO SEND BOTH UNITS IN FOR US TO TEST I WOULD BE GLAD TO DO THAT FOR YOU BUT MOST LIKELY IT'S THE ANTENNA." I have replaced the battery and now the red light goes out indicating a satelite has been found but I still don't get a reading. I will check all connections for corrosion etc., but I am not optomistic. Looks like I will have to send it back. |
| All times are GMT -5. The time now is 06:32 AM. |
