Where to mount pressure gauge fitting?
Lost the raw water pump in my runabout a couple of weeks ago....
I bought a Livorsi water pressure kit.
Where is a good spot to mount the fitting? The high temp alarm is mounted on the thermostat housing. It obviously doesnt work, so I thought about putting it there (nice and easy). But I don't think I would see an accurate pressure reading, as that's right where the manifold water dumps are. Where are you guys mounting your pickup fittings?
Merc 454
Merc 454
No, I have a Dart manifold and there is a plug in the water jacket next to the thermostat housing. You could also put it in the block, but it is more likely to get mucked up with dirt.
Ah gotcha. This boat is all stock and there is no plug on the manifold for water. I thought about the head but that may be tough to get to. Coming off of the block will probably get full of junk. I'm going to try and put it on the thermo housing (easy) and see how that does.
If it is a stock 454 manifold...
there should be a plug just left of the thermostat opening ON THE MANIFOLD, not on the big housing that bolts to the manifold.
It is one of those that you use a 3/8 extension to remove.
The water pressure sensor may be threaded smaller than this opening, however, you can get a brass adapter at the hardware store. Actually, the adapter may come with the sender.
Scott
Scott
