Merc TB ign VS 500 hp module
Recently I bought a couple of new/used 500 HP modules off this board. My purpose was to use these with the stock Merc TB distributors and coils. I was thinking that they would be simular to the original type 4 pin modules and and I would need was the plug to wire them up. However after recieving them I see they are a completely different pin/plug type. Can these still be used with my set up? I liked the advance curve they have however do I need the other 4 pin type or can these be used?
thanks for your help. The HP 500 modules are for carbed |
any replies........
Originally Posted by getrdunn
(Post 2923429)
thanks for your help. The HP 500 modules are for carbed Is there any advice or knowledge on this? I would really like to use this set up however not familiar with the 500 Hp modules as well as the pin configuration it has. |
Carbed 500hp's used both TB IV ignitions and TB V ignitions depending on the year. I'm guessing that you have a TB IV in your boat and you bought TB V modules.
Thye switched to TB V's in 1997-1998 carbed 500HP's. |
1 Attachment(s)
Originally Posted by Griff
(Post 2925210)
Thye switched to TB V's in 1997-1998 carbed 500HP's. here is what I have including new merc coils not in the pic. Since being away from the boating scene for a while I never gave it a thought in regards to the modules. So will the modules I have work with the dist. shown. If you need a pic of the 500hp module that I have I can probably post one. Also if they will work does anyone have any harness's Thanks, John |
I really don't know much about the interchangeability between TB IV and TB V components.
A TB IV module pretty flat and is mounted on a triangular steel plate. |
(Post 2926217)
A TB IV module pretty flat and is mounted on a triangular steel plate. at this point i may just have to look for the old style lfat (4 pin) as you mentioned. unless i hear different. i may have two hp 500 modules for sale.. john |
| All times are GMT -5. The time now is 05:27 PM. |
