-   -   Boat is Leaking Advice needed. (https://www.offshoreonly.com/forums/general-q/215196-boat-leaking-advice-needed.html)
cocktails 08-19-2009 09:55 AM
Originally Posted by 89Mach1 (Post 2934708)
Had a similar problem last year on a different boat. The exhaust Y pipe was loose and could only tighten the 2 top bolts and took about 3 hours to tighten best I could without pulling the motor. There was no way I could get to the bottom bolts, but it did cure the leak about 95%. There was about a 1/4" stream coming in before, and after the bilge pump would only kick on if I left it in overnight. Sold the boat this spring though and told the new owner about it, he didn't seem too concerned though...
My exhaust block off plate is installed no Y-pipe
rockstar342 08-19-2009 12:41 PM
Probally forgetting the drain plug after too many cocktails. I have seen this guy in action.
FlyinZX14 08-19-2009 01:00 PM
are the bolts holding the t/a to the hull good and sealed? Just had a boat in the shop that was leaking there, weve been chasing this leak all summer and found it was those bolts...
good luck!
cocktails 08-20-2009 11:08 AM
good luck!
I did not load up the bolt holes through the transon with caulk but the T/A rubber seal was brand new. If I remember correctly all the bolts are inside that seal. I don't see any water leaking from bolts.
cocktails 08-20-2009 11:09 AM
For your information I only did that once. The other time the bilge was filled with beer I spilled while drinking trying to fix the starters.
89Mach1 12-13-2009 03:12 AM
Ok, but there are still bolts that hold it on tight right? Just a thought, but might want to check anyways, you never know...
fireboatpilot 12-13-2009 03:03 PM
Check those bottom 2 bolts that come thru from the outside and will always be under water. I don't trust those TA seals and caulk them as well. Sometimes it pays to start over. Maybe several times. It's amazing how much water can come thru a pin hole.
seafordguy 12-13-2009 03:16 PM
I caulked mine as well when I reassembled....
