-   -   What coolant for 496HO? (https://www.offshoreonly.com/forums/general-q/215342-what-coolant-496ho.html)
richard 08-20-2009 04:15 PM
Hi, do you know what coolant to use for a 496HO.
From what I've read it takes pure coolant, no water mix so wondered what spec coolant it can take, and what type is normally in it?
Richard
DOUBLE OR NOTHIN 08-20-2009 04:55 PM
Use the red dex- cool, you can mix it with water... Hope that helps
SDFever 08-21-2009 01:04 AM
Richard
I believe the pure coolant you read about was the Merc branded dex cool. It comes pre-diluted with water so you don't add additional water to that product.
Remember, pure anitfreeze will freeze when cold. If you use standard dex cool (not merc) then mix it with water about 50/50 or 60/40. If you live where it gets much below 30 degrees, just use merc or find out what the manual calls for on the mix ratio.
LAKESIDE RESTORATIONS 08-21-2009 07:29 AM
If you want the best stuff, drain it all out, flush it & run Shell or Cat ELC style coolant.. It's a bit more $$ but a lot better stuff.. ;) Jamie / Lakeside
