Siphoning Gas
I have H2O in my tank. What is best way to get the gas out? Should I go through the fill or from the pick up to the engine?
Matt |
This may not work for you, but here is how I do it. I drain what little fuel is left at the end of the season and put it in the truck. I have aftermarket MPI, I disconnect the fuel hose from the fuel filter. Then I direct wire the fuel pump, I fill up 5 gallon containers untill the pump starts sucking air. You most likley have a mechanical pump. I hope that helps. Better to take the time to remove bad fuel than to ruin a engine.
What i done with mine was remove the fuel sending unit located under the seats and drained with my oil change pump for removing oil through the dipstick.
If you dont have an anti-siphon valve you can put a hose from pickup in tank thru the drain plug hole, block off tank vent, use a shop vac or air compressor to blow air into fill neck for tank(little air at a time) it will push the gas out the hose and you just keep filling gas cans till tank is empty.
Using any kind of electric pump other than a fuel pump could be hazadous to yourself and others! PS: If you have the anti-siphon valve remove it and replace with regular fitting and put it back when your done |
Thanks for the input everyone. Any suggestions on how to get rid of the gas water mix?
I bought a boat a couple years ago that sat for 3 or 4 years and I siponed it thru the fuel sending hole and local waste management place took the 25 gallons of old fuel. (they burn it in the incinerator). They even loaned me a collection of 5 gallon cans.
Originally Posted by fobes
(Post 2937074)
(Post 2937074)
If the fuel has any ethonol in it I wouldnt do this, the ethonoal is hdroscopic and absorbs the water. Not worth the headaches for some free gas IMO.
Originally Posted by blue thunder
(Post 2937261)
I had about 75 gallons of that a few years back. I siphoned it into a 55 gallon drum and some 5 gallon cans. Because water and fuel seperate, I then siphoned off the fuel from the top of the barrel and burned it in my cars. I dumped the five gallon containers of water/fuel mix into the barrel as it had room. The 5 or so gallons of water/fuel left at the bottom of the barrel when it got low I mixed with spent motor oil and used to start my burner barrel and bon fires.
Originally Posted by happy hours
(Post 2937352)
Just dealt with this. used vacuum pump to pull out most of the tank (water and fuel) through the fuel pick-up. added some dry isopropanol to the tank and filled with fresh gas. no probs after. poured fuel off the top of what was pulled out until mainly water left. mixed it with recycle morot oil and the rest I put in cans to burn in mowers, etc...
if you have more than you'll use in your mower, donate it for neighbor use... |
Post #6.
the 10% ethanol with absorb water and never settle out. QUOTE=blue thunder;2937375]i disagree that this would not be a quite satisfactory approach ethanol or not. Water is water and it will go to the bottom even if there is 90% fuel, 10% ethanol vs 100% fuel. What is your proposal for getting rid of the fuel then, dump it out behind the garage :eek:?[/QUOTE] |
(Post 2937706)
Post #6.
the 10% ethanol with absorb water and never settle out. QUOTE=blue thunder;2937375]i disagree that this would not be a quite satisfactory approach ethanol or not. Water is water and it will go to the bottom even if there is 90% fuel, 10% ethanol vs 100% fuel. What is your proposal for getting rid of the fuel then, dump it out behind the garage :eek:? ethanol / water mix will phase separate as more water is added. the water rich phase on the bottom won't burn, but the phase on the top which will have less ethanol than the original mixture as well as less water will be fine to burn in normal stuff - especially if diluted with more fuel or if dry alcohol is added to further increase the water carrying capability of the fuel. not much different than putting drygas in your tank to run water through that builds up from condensation. burn the stuff onthe top, let the bottom evaporate in a can or something and throw the remaining sludge away. no worries... if you;re worried about what to do with the very little bit left after the water and ethanol evaporate from the bottom 9mailny water) layer, then mix it with motor oil you talk to the recycle station. it'll get blended into fuel oil and burned in a powerplant to recoup the btus from the oil... |
Unless you need a new lawn mower or a new engine in your car don't burn it there either. Have it disposed of properly, there are people that do that.
| All times are GMT -5. The time now is 04:01 PM. |
