3 Attachment(s)
Originally Posted by MER Performance
(Post 2937175)
Super clean set-up! What size are the strainers? Why, did you go to a 1" longer lower? Becareful testing this,you could very easily cook the cylinder heads. Read the temp with a temp gun on the cylinder heads in all 4corners of the manifold at the water outlets, frontand rear. Is your oil temp climbing also and not coming down? I just went through a very costly problem on a top gun. This was posted on the other site SOS under 38 Top Gun cooling problems, if you want to look at it. http://www.seriousoffshore.com/forum...ead.php?t=8435
Originally Posted by aTX427
(Post 2937234)
I have never had sucess with those thru-hull pickups. You should consider a transom mounted pickups with a lead in groove and install pop-off valves on the strainer to bleed off excess pressure. I used a 1.25" diameter pipe wrapped in sand paper to create the lead in groove. It is 5" long and about 3/8" deep. The pickup does not extend past the bottom of the hull. I would also either block off the the drive fed pickups at the inner transom plate. If they pull air, you will continue to have pressure problems. You should also weld a center plate inside the pickup to prevent larger pieces of debris from clogging the pickup.
5 Attachment(s)
this is what Im doing,the thru the knotch or botton would of benn cheaper:(.I Redesing the one on the left:drink:
Originally Posted by Strip Poker 388
(Post 2937371)
Those sportmasters will support enough water, they have to be modified on the openings, you can do it with a die grinder or better tear the lowers down and set them up in a milling machine and end mill the inlets larger and deeper lead-in grooves, if you have a step bottom, I can bet you are getting air in the water system, if so you need to dump the air from the top of the strainers to below the water-line when the boat is not on plane. you can run on 15 psi water press, but, without the air, they will support at least 800 HP for sure. I had a 2004 Top Gun with the same problems. Air is still going to be there on a stepped bottom.
(Post 2937436)
Originally Posted by Velocity Vector
(Post 2937278)
I would rather have transom pickups but to get them installed I'm thinking I would have to pull headers to get at them is why I choose the thru hull's. I'll be 21 inches in front of the transom. Do you have to pull the drive to get to the inner transom plate? I also have 12" Imco extension boxes.
| All times are GMT -5. The time now is 07:24 AM. |
