-   -   CMI E top. one warmer than other ? (https://www.offshoreonly.com/forums/general-q/215424-cmi-e-top-one-warmer-than-other.html)
Highdollarcarguy 08-21-2009 08:04 PM
Ok ! Just installed a pair of CMI e Top. they were used and tested 80 psi 2 hours.
Sound great. Noticed the left (facing motor) Header was much warmer that the right. The right header was very cool.
Engine fires right up and idles good. oil pressure good.
was wondering if the internal flapper is creating an issue ?
Seems that there is more water coming out of the cooler exhaust.
I did notice a leak at the warrm header tail pipe. water dripping slightly. that was the tail pipe I replaced the new rope seal. I'll get that tweaked Saturday to stop that from leaking. But was wondering why one side would run warmer ?
Thanks gang ! BTW..... The engine is a 454. 430 hp.
Cheers !
Frankie B
LAKESIDE RESTORATIONS 08-22-2009 08:04 AM
Sounds like you may have a water volume flow issue that is needing to be balanced from side to side. If so you need to devise a way to distribute the water more evenly from side to side. ;) Jamie / Lakeside
Highdollarcarguy 08-22-2009 09:16 AM
Evenly distribute the water from Side to side ? I don't think I understand. Please advise.
I was thinking that maybe the internal flapper in the exhaust tip wasn't opeing as far as it should ? The bottom half of the left Header is cool the Riser portion is what's getting hot to the touch.
LAKESIDE RESTORATIONS 08-22-2009 09:52 AM
I doubt it is the flapper in the tip causing the problem. I have run into this before on units with aftermarket exhausts. Sometimes eventhough the flow at or off idle seems the same or similar, under loads or higher rpm it can change. Water follows the path of least resistance..
To answer your other question, By distribution, I mean making sure that both headers get about the same ammount of water flow thru them or restricting one side slightly to force more cooling to the hotter side. :)
If you are not able to do this yourself, I suggest taking it to a shop that can. I can also do it for you depending on if you want to make the drive or need me to do it.. :)
Jamie / Lakeside Restorations
CB-BLR 08-22-2009 09:58 AM
Talking about water lines:
On merc racing motors, the hole going from the header to the collector... on the collector side... is slightly smaller on the starbord side collector, in order to equalize water flow to both headers. This increases water flow to the port side header.
Hope this helps,
Chris
Highdollarcarguy 08-22-2009 10:39 AM
Thanks Chris....
Jamie, NE Pa is a stretch for me brother. Tell me how you would correct the problem and I'll try and tackle it and give you an update when I accomplish the task.
I've replaced the oil cooler, High volume Edelbrock water pump, New sea pump, New Thermostat.
Would you curtail water flow from the Thermostat housing ?
I would like to note. I did replace the Header's rubber distribution tube on the side that is running warmer. the reason I mention this is because the distribution tube on the warm side (the side with less water flow) has a longer distribution tube than the cooler side. Should I trim Up the distribution tube to match the length coming off the header on the cool side ?
Send me your thoughts on this and your expertise on how to correct the uneven flow distribution.
Thanks again!
Frankie B
LAKESIDE RESTORATIONS 08-22-2009 11:22 AM
I already have made a recomendation.
Sounds like you may have a water volume flow issue that is needing to be balanced from side to side. If so you need to devise a way to distribute the water more evenly from side to side. Jamie / Lakeside
There are a few ways that it can be done. Basically if this is your problem it is usually remedied by slightly restricting water flow on oneside to make more water flow to the other side. Just shortening a hose wont necessarily fix that.. Unfortunatley there isn't really anything else I can tell you or help you with beyond that without the boat being here for me to check thru.. :)
If you were closer, I'm sure I could get it straightend out for you pretty quickly, But I do understand about the distance.. :) Jamie / Lakeside
