-   -   Paging Griff (https://www.offshoreonly.com/forums/general-q/21543-paging-griff.html)
nobudget 04-03-2002 07:27 PM
Paging Griff
Griff: Thanks for the advice: This is NOBUDGET.
You had given me advice on a cam selection for a 365hp.
Ordered the cam and springs matching the part #s you gave me.
I was wondering witch Roller Rockers you went with .
As well as witch timing chain you went with.
Thanks Again NO BUDGET
Griff 04-04-2002 04:32 AM
I used the Crane timing chain set also(part #13993-1). I used the Summit brand 1.7 roller rocker arms(#G6930). They are a little less money than the Crane Golds and quality looks comparable. Actually, they look identical except they are black. You could probably go with the Crane Energizers to save a few bucks.
Also, you will have to cut/grind off the oil drip tabs on the inside of the valve covers to get enough clearance for the roller rockers and use the thicker steel core valve cover gaskets.
nobudget 04-04-2002 07:54 PM
Griff: Thanks again I will have all the parts, in a week or so.
After the valve train is set up I should be under way with the rest of the motor. I will let you know how it turns out. Thanks again
for sharing your part #'s and advice, it has been very helpful.
Nobudget!
Griff 04-05-2002 04:27 AM
Anytime. Good luck with the project.
