-   -   What size oil lines (https://www.offshoreonly.com/forums/general-q/215437-what-size-oil-lines.html)
Rudd Jr 08-22-2009 06:20 AM
What size oil lines
I have a set of Gen 6 engines very very similare to the hp 500 carb version.I'm still running the stock block adapter. I need to replace the oil lines to the remote filter and cooler, can I use #8 aeroquip fittings and lines.I allready know bigger is better, but i have a ton of #8 stuff and would rather not spend the bread for new block adapters fittings and braided hose If it wasn't necessary. Any help would be appreciated.
jeffswav 08-22-2009 06:38 AM
I use 12 AN lines and fittings. The Canton Racing adaptor is much better. Do a search for "oiling system with stock hardware".
Ghostrider 08-22-2009 08:15 AM
Another vote for AN-12 as a standard. Run the AN-8 for fuel at a minimum. You need the size for oil to ensure it flows at sufficient volume, not just pressure, eslpecially when cold. AN-8 would generate VERY high pressures and never flow nearly enough. Sorry to be the barer of bad news but I found out the hard way and I wouldn't want for you to do the same!
Seriously though, read up on this thread:
Oil Pressure Problems...
MER Performance 08-22-2009 08:47 AM
Artic Friends, did a complete thread on this subject.
http://www.offshoreonly.com/forums/g...-hardware.html
Rudd Jr 08-22-2009 09:11 AM
great info !! thanks alot guys. guess I need to break out some bread and upgrade.
aTX427 08-22-2009 10:36 AM
I think -8 is too small. I believe the 500HP uses -10, as do the 700sci's.
tx911 08-22-2009 02:51 PM
Dont cut corners on your oiling system. Ask me how I know
stevesxm 08-24-2009 01:27 PM
there is absolutely nothing technically correct about this information unless the information is coming from the batman and robin comic book version of the fluid dynamics handbook.
a melling oil pump, typical to a big block chevy will max out i.e to say will NOT exceed 6 gal per minute before it cavitates. so thats the number.... 6 gals per minute.
a 5/16 line will move 30 wt oil roughly 5 times that number.
a 3/8 line will move roughly 10 times that number
the presure never changes because the relief valve sees to that. if it didn't the system would hydrolock and the filter would explode.
the factory, and i'm talking about guys with real degrees who actually know what they are doing and aren't talking out their ass use 3/8 lines and they are correct.
the people that are suggesting that -12 lines are an improvement in any sense what so ever under any circumstances don't know their asses from a hole in the ground and it would be really nice if you stopped promoting this voodoo like it was meaningful.
jeffswav 08-24-2009 03:28 PM
Thanks for calling us stupid for using 12an lines. My engine has not blown up since I upgraded my oiling system from stock form. Thats all the proof I need. I upgraded the Adaptor all the fittings and lines and modified the filter housing. Since then no problems. Just giving my personal experence to try to help somone out.
Kidnova 08-24-2009 07:09 PM
Rudd - do you have oil temp gauges? If so, what is your oil temp at cruise, and at WOT? btw.... if you don't have oil temp gauges, it would be a good idea to install them.
Also, what's your oil pressure read at idle, cruise & WOT?
Answers to these questions will make it easier for the members here to help out.
fastlane40 08-25-2009 06:03 AM
i run 1/8" and mine work fine
PatriYacht 08-25-2009 07:59 AM
Steve, don't measure the hose size, measure the size of the fittings and elbows etc. The square inches are less than half the size of the hose. That being said, -10 is large enough for typical wet sump engine with a high volume oil pump. Larger just costs more. If I were building a 1000hp dry sump engine, I would use -12.
Throttle Fever 08-25-2009 09:13 AM
Agree
Have to agree. Your pump will only move so much oil, look at the output hole in the pump. I run -10 on oil just because that was the size all my block fittings were. Never saw any pressure or temp differance after replumbing from stock 1/2" Mercury stuff.
jeffswav 08-25-2009 01:51 PM
Pop the hood on any NASCAR or regulated racecar circuit. I don't recall seeing any restrictive fittings on them. AN stands for Army, Navy the military uses that as a standard. Sure 10AN would work fine also. But the cost was very little more to jump from 10 to 12. But that rubber hose with restrictive fittings does't flow well at all. Anytime you add 100 or more HP the stock setup does not flow enough oil. I am not a engine builder, I just know from working on my own boat, and researching what others have done. Havent we already when through all of this in another post. I feel like we are beating a dead horse.
