-   -   Trim Pump Question (https://www.offshoreonly.com/forums/general-q/215617-trim-pump-question.html)
smcclay 08-25-2009 08:09 AM
Trim Pump Question
I think my lines are backwards, the black hose is connected to the "up" port on the pump and the gray hose is connected to the other port. I can't read the second port label where the gray hose is connected as it's smudged.
Elite Marine 08-25-2009 09:59 AM
Hoses are not typical or standard color coded. If they are switched, swap them.
tony davis 08-25-2009 11:31 AM
grey is normally "up"
smcclay 08-26-2009 08:18 AM
Thank you for the heads up. I will move the gray hose to the up fitting and conform to the norm.:drink:
