-   -   Crank ID (https://www.offshoreonly.com/forums/general-q/215668-crank-id.html)
OhioRiverCigarett 08-25-2009 07:56 PM
Crank ID
How can I ID a crank? How do you tell if it is a Mark IV, Gen IV or Gen VI?
Are then interchangeable?
tx911 08-25-2009 08:27 PM
The mark 4 will be a two piece rear main seal crank. Gen5/6 are the same, one piece rear main. get the casting number off of it and look it up online, or post it here and someone will help.
tx911 08-25-2009 08:29 PM
BTW, you can use a two piece rear main seal crank in a one piece rear main block with an adapter. But not the other way around.
cbellamore 08-25-2009 09:11 PM
post up the casting numbers
Griff 08-26-2009 01:27 AM
Look up the casting number here http://www.mortec.com/
OhioRiverCigarett 08-26-2009 07:36 PM
Where to fit casting #
Where on the crank is the casting #'s?
