-   -   closed cooled ? (https://www.offshoreonly.com/forums/general-q/215672-closed-cooled.html)
crayolacrazy 08-25-2009 08:58 PM
closed cooled ?
can someone explain why mercury closed cooled engines have restricters in the water flow to the tail pipes 525,600,700 s
CB-BLR 08-25-2009 10:23 PM
On the 525 motor, some restriction is needed on the starbord collector to equalize water flow from the heat exchanger, and keep the headers on both sides aproximately the same temperature. On this motor, I think they are restricted too much.
On the 600sci and 700sci, the tailpipes are restricted to force water thru the whipple type innercooler.
I personally think that there needs to be more water flow to the 600 and 700 motors. There are lots of people that have had smartcraft water pressure issues because of merc's water setup on these motors. These proplems are usually solved by installing a seperate water pickup and strainer for the innercooler, then opening up the restrictors in the tailpipes.
Chris
Boat Tech 08-25-2009 10:27 PM
Do you mean resonators inside the exhaust hose by the tail pipe? http://www.boatfix.com/merc/Bullet/00/00_13.pdf
CB-BLR 08-25-2009 10:37 PM
No.. we are talking about the water restrictors in the tailpipes that control water flow leaving the cooling system. Parts 14 and 15 in this diagram of a 600sci exhaust system.
http://www.mercruiserparts.com/Show_...lpipe+Assembly
Chris
crayolacrazy 08-26-2009 06:21 AM
Chris
heres my problem when im running 1,2 footers I over heat, the motors take turns my transom mount adjustable pickups cool the motors going to large sea strainer, imco drive pickup go,s to inner cooler. when this happens I have to stop shut down start right back up it cools right down I have496 base engines with wipples 810 hp 7lb boost this happends at all speeds Does the sea pump need some back pressure ,when I lower my scoops water pressure gets way over 30 psi MY scoops are 2 ichs above pad on the angle of the keel and carved to direct water this problem does not happened in flat water it seams like the gulp of air gets traped in heat exchanger .I have been chasing this issue sinse I installed cmi,s
Smitty 08-26-2009 08:51 AM
You should be using the drives for the engine water and use the transom pick ups for the intercoolers. That is how I run it and I have no issues at all.
When you are in 1-2 waves, you are introducing air into the system because there is not a consistant flow of water to the pickups on the transom.
CB-BLR 08-26-2009 09:31 AM
Smitty is correct.
You should have the drives feeding the engines, and the pickups feeding the innercoolers. On a closed cooled motors, mercury racing suggests 30-50 psi as normal running water pressure at wot.
On a smartcraft equiped motor, if water pressure drops below 26psi, with the motor above 5200rpm, the computer will throw a fault code. If the water pressure drops below 21psi with the motor above 5200, the motor goes into guardian mode, and will reduce power.
Remember... on closed cooled motors, the engine is not seeing any water pressure from external sources. Water flow is regulated by the restrictors in the tailpipes, and/or the restriction in the innercooler. The block is running antifreeze, and the only pressure on it is caused by the circulating pump, on the front of the motor.
Chris
P.S. I typically have water pressure in the mid 40's at wot.
crayolacrazy 08-26-2009 07:45 PM
do you have closed cooling
crayolacrazy 08-26-2009 07:49 PM
no 6 boats all use pick ups not the drive so what do they do
crayolacrazy 08-27-2009 06:08 PM
I have cmi headers ,install 2 years ago could never touch them ,also have 5 inch heat exchanger so this year we added the pickups thinking that it will run nice and cool come to realize that the headers didnt have any restricters I looked at all mecurys closed cooled motors so I added some ,still messing around with pressures now I can touch my headers also I have gauge set up too . I do think I needed the restricters allalong Ill be testing this week end and lowering the scoops
Smitty 08-28-2009 10:11 AM
No I don't have closed cooling. That should not matter. Problem with transom pick ups is when the boat leaves the water as it does when it is slightly choppy, you introduce air into the system which is bad.
crayolacrazy 08-28-2009 05:37 PM
the reason I ask about the closed cooled on your boat is that you can get by with alot less water pressure
Rage 08-29-2009 04:40 AM
What coolant and oil temperatures do you see when you over heat?
crayolacrazy 08-29-2009 08:25 PM
coolent temp gets to 160 oils still low wipple has ecu pulling timeing and fuel at 160 coolent temp. I run 120 themastats normal temps are 138 -142
CB-BLR 08-29-2009 09:39 PM
1 Attachment(s)
My coolant temp runs between 140 - 150 deg, and my oil temp runs between 165-185 deg. I run all my water thru my outdrive. Water psi is 40-43 at wot. Top speed is 93mph.
Chris
P.S. I have modified the nosecone of my IMCO lower in order to pick up more water.
Rage 08-29-2009 10:43 PM
So on smooth water your coolant temperature is 138 -142 at WOT and in "1-2 foot chop" it is 160F at WOT? Is that correct?
What is the oil temperature number at WOT?
crayolacrazy 08-30-2009 12:35 PM
it takes a few miles ,and it switchs motors and It dont even have to be at full throtle I think its where my pickups are located combined with no resricters in the headers I like the way that imco was altered SO, CB-BLR how do you get water to your innercooler?
CB-BLR 08-30-2009 12:52 PM
I tee off the main water line.. just after the raw water pump. This is where Dustin Whipple told me to do it. He told me that this should work, and had me modify the nose on my drive also in order to get more water flow when trimmed up.
He said that if this didn't work on my particular boat, that I should put a transom pickup with a seperate water strainer for the innercooler, and just run the water for the motor thru the outdrive.
Chris
crayolacrazy 08-30-2009 02:45 PM
Chris
what motor did you start with ,and is it a single or twin ,and what exhaust? and do you have resticters in the exiting waterflow?
CB-BLR 08-30-2009 03:03 PM
Single engine.. Merc 600sci .. Whipple Stage II upgrade .. 735 horsepower.
Chris
crayolacrazy 08-30-2009 03:12 PM
Chris
so you do have restricters in you waterlines
CB-BLR 08-30-2009 03:21 PM
Yes, I have restrictors in the tailpipes as outlined in the BAM drawing I posted above.
Chris
crayolacrazy 08-31-2009 07:37 PM
thanks for all the input guys
