-   -   Dart heads ??? (https://www.offshoreonly.com/forums/general-q/215881-dart-heads.html)
alecsammy 08-29-2009 09:11 AM
Dart heads ???
Hello,
I have a gen 6 502 with small dome pistons . I'm looking at getting a set of alumumin or Iron eagles heads . The engine is carbed are the 325 aluminum or the 345 cast iron heads too big . Any input pro's and con's . Thanks Jp
Car Biz 08-29-2009 10:59 AM
Originally Posted by alecsammy (Post 2942141)
Hello,
i bought the Summit BBC heads 308CC When they came in the box the inside of the head had "Iron Eage " stamped in the head with Summit engrved on the outside! They seem to be a good head for 1400 complete!
MER Performance 08-29-2009 06:08 PM
Hello,
345 would be to large. Call Bob, RM Builder for the CORRECT HEAD AND CAM SELECTION.
BenPerfected 08-29-2009 07:20 PM
We have had great success with the Dart 308's We have used most of the configurations of the GM, World and Dart BBC cast iron heads over the last 20 yrs. The Darts are in a class by themselves. In our experience, the 310-325 CC intake runner is where you want to be for 500-540 CI marine. With porting, both the intake and exhaust ports can be improved if your HP goals and budget allows.
mrhorsepower1 08-30-2009 03:55 PM
I all ready have........many times.
mrhorsepower1 08-30-2009 03:58 PM
The ultimate head to make the most power is actually an oval port design with a runner volume of 309 - 315 cc. I have developed this cylinder head intake package back in the A and B class days as BenPerfected knows. These 9.5:1 engines made 798 HP with 1 X 4.
BenPerfected 08-30-2009 04:43 PM
Also as Dean knows, we never made as much HP as he did! We didn't figure out the A/B class combination until the last year of the classes :mad:
mrhorsepower1 08-30-2009 07:17 PM
Those were the days !
Rookie 08-30-2009 08:40 PM
Hello,
Yes they are to big. I just asked Jim V this question. 308's would be better. Give him a call and he can tell what you need to put on your 502. He might have something laying around the shop or can also get you what you need. He's also pretty good at getting some power out of the Darts and 502's :)
616 889 0928 Its worth the call to at least get some ideas.
Rookie 08-30-2009 08:41 PM
2003 the year the APBA died in my eyes :(
baja27 08-31-2009 07:37 AM
I thought you can not use the dart heads on a gen 6 block?
mrhorsepower1 08-31-2009 10:28 AM
yes you can. You need to run the correct head gasket
KAAMA 08-31-2009 12:37 PM
Can the Kieth Eickert 2-piece valve cover be used on new the Dart 18* OVAL port CNC'd head without any mods or problems???
Also, I would think the EXHAUST PORT of the new Dart OVAL port CNC'd 18* head is pretty good the way it comes from the factory for a marine blower application---right???...does anyone know if more port work to the exhaust port would be bennificial??? Thanx, Mark
wanab 09-12-2009 05:19 PM
they sure where.
what kind of lift where you running to make those numbers?
