-   -   1.5 to 1.36 (https://www.offshoreonly.com/forums/general-q/216379-1-5-1-36-a.html)
chess1 09-07-2009 01:12 PM
1.5 to 1.36
okay, I blew out my 1.5 over the summer. I am turning a 23 mirage plus prop at 5K at about 70 gps. I went to a 1.36 and kept the same prop to see what the RPMs were turning it. Another words was the 23 the max for the boat or could I use more. Well that was it. I have a 502 mpi and with the 1.36 and 23 prop I turned 4200 rpms. My question is do I need a 19 or 21 pitch prop? My math tells me I am going to lose about 5-6 mph either way. Thoughts?
GPM 09-07-2009 01:44 PM
5000rpm, 1.5 gear and 23 prop @ 70mph is only 4% slip, don't know if that's possible but useing those numbers the 21 pitch with 1.36 gear @ 5k if you can get there should be real close to the same speed.
elise909 09-07-2009 05:31 PM
Each number you change expect a 200-300 rpm change. A 21 will probally give you 400-500 more rpm. 4200 rpms on your first run a 21 will proballly get you closer to 4600-4700 rpm. Some times you have to take a 19 and have them worked with to get it exactly as you want it. but the 19 will probally give you 800-900 more rpm and put you close to 5000rpm peak hore power on that motor is probally close to that or a little less.
good luck
wtfo 09-07-2009 09:16 PM
that's the way to do it - if you treat the prop pitch like just another gear it's a simple ratio to figure out the pitch conversion. it is easy to us a prop slip calculator like the one below, plug your current numbers in and, get your theoretical speed, then put your new gear ratio in and click on calculate above pitch. This assumes two things: that the two props are the same efficiency at turning torque into thrust, and that the horsepower and rpm of your engine is the same at wot (for a given set-up max hp pretty much determines top speed). Not perfect, but a good place to start for sure.
I think I remember reading or hearing somewhere that mirage plus props are usually a little over pitched ie act like a little higher than the officially numbered pitch they're given. that puts your calculated slip more like 8%, still probably a bit low. maybe the tack is off a little too... pretty common. ;-)
http://go-fast.com/Prop_Slip_Calculator.htm
ps. where can I get me some of that hore power?
chess1 09-07-2009 09:27 PM
Thanks for all the replys. I agree that the tac may be slightly off and the 23 mirage plus is more like a 24. The boat came with a 24 4 blade.
jeffswav 09-08-2009 09:16 AM
Your tach must be off. Your numbers do not match up. Here is another website to check out. http://www.rbbi.com/folders/prop/propcalc.htm
elise909 09-08-2009 01:21 PM
Sorry for the typo; well said wtfo.
Griff 09-09-2009 12:54 AM
If you were only turning a 23 M+ with 1.5's, then you should not even be going to a 1.36.
rhsj2006 09-09-2009 07:00 AM
Yes, I'm curious why youre making the switch to a shorter final ratio. No details given on hull\engine combo, but if you're seeing top speed of 70 at 5k with a 23" prop and neither lagging the engine or bouncing off the rev limiter, your setup was pretty solid.
obnoxus 09-09-2009 10:10 AM
your going to need to drop to like a 19.
you will have decreased performance all the way around.
much better off repairing the 1:50
Brad Zastrow 09-09-2009 11:25 AM
Agreed. The 1.36 was not the way to go.
Fixxxer22 09-09-2009 11:29 AM
I have a 1.36 also on a 24 outlaw. have a 500hp and run a B1 24p 4 blade. Hate the 1.36 hopefully in winter change gearing to 1.50. Repeat: HATE THE 1.36! Do not have enough power for it. Poor planing.
