-   -   Sealant for risers gaskets? (Cast Merc) (https://www.offshoreonly.com/forums/general-q/21644-sealant-risers-gaskets-cast-merc.html)
patrick22309 04-05-2002 08:27 AM
I plan to split my riser from my manifold this evening to investigate my water flow problems and am not sure what to use to put them back together. I have NEW gaskets but not sure if they require and sealant?
patrick22309 04-05-2002 08:31 AM
By the way, any of you guys know Art Lilly? I am asking all these question about a Stingray boat I purchased from him. He is a good guy and let me know of problem areas before I purchased the boat.
ursus 04-05-2002 09:03 AM
Merc service bulletin for exhaust manifold and risers, it sugests Loctite 510 sealent, good info to read for inspecting reassembly procedure
http://www.sterndrives.com/bulletins/mc/99/EN_010.PDF
Mbam 04-05-2002 12:18 PM
The latest gasket is a graphite composite and does not use any sealer. It is kind of silver metallic looking. The sealer was a previous setup. I is best to use the new gasket, seems to work better than the previous versions.
