Max cubic inches out of Bowtie block ?
What is the maximum cubic inches you can get from a Bowtie 502 block and what pieces do you need to get there ?
Bore 4.560 if you sonic test and a 4.25 crank would be safe. 557CI
588
Originally Posted by Griff
(Post 2951371)
588
4 3/8" stroke Chris |
Personally, I wouldn't put a 4 3/8 crank in a 9.8 deck height block. The rod angle is to steep for my taste. I would stick with a 4.25" crank and you could go all the way to 4.600. That would make a 565 ci. You can take that block to 4.625" bore as long as you sonic test it. You should still have .250-.300 wall thickness at 4.625" bore. I have taken countless bowties to 4.600 with no problems.
Eddie |
I had a 502 bowtie at 4.600 with stock crank (think it worked out to 525 cu.) ran great with an easy 600 hp/600 ftlbs. at 9:1 compression with Dart intake and EMI exhaust. Loved that engine!!
Originally Posted by raeburn
(Post 2951408)
Eddie |
Could you guys explain Sonic Testing? Are you checking the thickness or strength of the cylinder walls? And you do this before boring, right? Otherwise you've ruined a block that could be used with less bore. Am I close?
Thanks for the input guys.
Originally Posted by Payton
(Post 2951467)
Shafiroff Racing has a 598" out of a short deck :eek:
what about the merc 9.8 deck blocks 502 415 hp/ 502 500 hp /502 525 hp, I believe all three are the same siamise bore blocks not a bowtie or are the blue bowtie. I have a 9.8 siamise block can that be bored to 4.6 max or under?? thinking about making it into a 540 as my back up to my bowtie 572. cause its been sitting for 3yrs as a 509. thanks
Gen 5 marine blocks are a litle bit thinner than the gen 6. Gen 5 is 1994-95 I believe. Gen 6 is 96 on. Most gen 6 can go 4.600 but sonic checking is always a good idea. They are not as beefy as a bowtie and most builders say they are only good for 800hp or so.
| All times are GMT -5. The time now is 08:10 PM. |
