-   -   Engine coupler (https://www.offshoreonly.com/forums/general-q/216942-engine-coupler.html)
rssteiny 09-16-2009 11:44 AM
Engine coupler
On my 32 active thunder with 500 hps do i have to pull the motor to change the engine coupler.
Griff 09-16-2009 12:00 PM
More than likely, yes. It may be possible to just unhook everything and slide the engine forward enough to change. Probably just as easy or easier to just pull the engine.
Young Performance 09-16-2009 12:25 PM
I seriously doubt you will have enough room in a 32 AT to slide the engine forward enough. You will need to remove the bellhousing and shield and anything else on the back of the engine in order to access the coupler. Take advantage of it and replace or clean other items while you have the engine out. Good luck.
Eddie
speedfever 09-16-2009 02:47 PM
pull engine to make it easier on yourself....
