block choices
so i blew up my gen V 502 and the block is no good, so i have a choice of buying a 502 block or getting a gen V 454 for free then stroking it to a 496. What kind a HP and torque difference would i see between a 502 and 454 stroked to 496. Also i have a side mount whipple so i cant go to big on the cubic inchs, so ive been told. Thanks
mrfixxall
Originally Posted by conquest30'
(Post 2953879)
plus i have the 2.3l whipple side mount? so u think i would be better off with the 454 stroked over a 502? would the 454 have good top end and hp compared to a 502?
mrfixxall
(Post 2954309)
just make sure you use main and head studs,. |
A stroker motor has more torqe, a 502 will rev a little higher for more HP. A 540 is better more torqe and HP. I have a 489 4.25 stroke .030 over.
well im not planning on reving the motor very high, max rpm of 5300 and the stroker motor should be able to do that, right? the reason i cant go to a 540 is because i have been told that would be to big of a motor for my 2.3 sidemount whipple, right? thanks for the help
I have a 540 with a 2.3 top mount whipple. 775 hp @ 5600 rpm with 5 lbs of boost. However, the blower will heat up and the hp will drop the longer it is in higher boost range.
mrfixxall
(Post 2954879)
what is the reason why you cant use the sidemount on a 540ci motor?
| All times are GMT -5. The time now is 06:29 PM. |
