closed cooling pick-up
Hello All,
I have a 502 with a fresh water cooling system , can I run the sea water thru the bravo drive or do I need to run an external pick-up to provide proper cooling for the heat exchanger.Any input would be great Thanks Jeff |
You can run through the drive. This is how all Merc's closed cooling systems are done.
External pickups will slow the boat down. Chris |
| All times are GMT -5. The time now is 11:20 PM. |
