-   -   new fuel pump started smoking (https://www.offshoreonly.com/forums/general-q/217145-new-fuel-pump-started-smoking.html)
lowpro 09-19-2009 06:39 PM
I just installed a new electric fuel pump on my 19ft 97 Scarab. It ran fine for awhile then the fuel pump started smoking. I turned off the engine. I tried it again it didn't smoke, sat at idle for a little bit then revved it a little and it started smoking again. Is this a faulty fuel pump or what?
PJDiesel 09-19-2009 07:19 PM
Hmmm, smoke and fuel may not mix too well for long......
I would say swap it out.
Rookie 09-19-2009 07:59 PM
What brand? Model?
Thunderstruck 09-19-2009 09:02 PM
Make sure you have big wires as short as possible with as few connections to the pump as practical. Good ground etc. Corrosion in the wiring or a bad connection in the wiring causes increased resistance in the wiring. The increased resistance will cause lower voltage at the fuel pump motor. A DC motor (i.e. fuel pump motor) will try to draw more current to produce the same power output. The high current will produce higher temps in the motor.
GO4BROKE 09-19-2009 09:23 PM
Thunderstruck is right on the money. Check your wiring, and replace the pump. Not something to risk a fire with.
Rookie 09-20-2009 11:52 AM
Also make sure you run it off a relay.
GO4BROKE 09-20-2009 04:13 PM
With a fuse.
lowpro 09-20-2009 06:18 PM
It is a Sierra electric fuel pump 18-7326 just bought it from West Marine. It does run off a relay.
