-   -   bravo to xr swap ? (https://www.offshoreonly.com/forums/general-q/217567-bravo-xr-swap.html)
rssteiny 09-26-2009 06:52 PM
bravo to xr swap ?
Will the xr drive slide rite into my bravo gimbal housing with out changing anything else like the trim rams or anything.
CB-BLR 09-26-2009 07:45 PM
Yes
t500hps 09-26-2009 09:12 PM
Originally Posted by CB-BLR (Post 2961187)
Yes
Well...except for the gimbal bearing. The XR bearings aren't as thick leaving room for an XR's larger u-joints. You will need to replace the gimbal bearing......but that's an easy $100 part you can do yourself.
jwurl 09-26-2009 09:59 PM
You need to replace the gimbal bearing and put spacers in the trim rams. Mercury sells a kit with all the parts needed with instuctions. I got mine from BAM. Jeff Wurl
Griff 09-27-2009 02:05 AM
Correct.
rssteiny 09-27-2009 08:19 AM
Thanks guys, is the xrs worth the extra money to hold up with 650 plus hp.
Pismo10 09-27-2009 08:32 AM
A regular bravo wont take 650 hp for long so it's worth a try.
monstaaa 09-27-2009 11:07 AM
the bravo will last quite longer than most think with more than 750 hp. it is the accelerating and miss throttling that kills them. brickin it out of the hole and holding it down while at speed in sloppy and ruff water will wipem out.
i have set up a conciderable amount of bravo 700-950 hp set ups. change oil every 10 hrs. eas ythrottling and moderate planing and accelerating will last you. and yes a decent while longer than a stock bravo.
nordic95 09-27-2009 09:09 PM
I wouldnt do it again.I also changed over to XR when I built my 600hp and in two years both upper gears sets have blown. Everyone tells me merc had bad gears and that the new ones should be ok now.Well after 3200.00 just for gears and about 400.00 for bearings later and now I am thinking of going back to my spare bravo ones to gain the speed I lost between the different drives.
Nordic95
jwurl 09-27-2009 09:42 PM
I did loose 4 mph when i switched to the XR. Jeff Wurl
rssteiny 09-28-2009 07:35 AM
Then what about upgraging the bravo upper to xr gears and going to a imco or sportsmaster lower. would this combination still lose speed.
nordic95 09-28-2009 07:07 PM
Its the XR straight cut upper gears that eat up the HP and speed. The lower gears are all straight cut for the bravo,XR,imco etc.
