-   -   HELP need seperator tank 1996 7.4 mercruiser (https://www.offshoreonly.com/forums/general-q/217612-help-need-seperator-tank-1996-7-4-mercruiser.html)
jimmie 09-27-2009 01:42 PM
Or maybe how to buy a replacement pump on the inside
Pismo10 09-27-2009 03:31 PM
This is a perfect time to rid yourself of the VST all together. Get a high pressure fuel pump, out of the separator, run it through a filter if you like, to the fuel rail, through a regulator and back to the tank if possible or back to the water separator at least. You then do not need a VST and will not have any potential VST problems anymore like vapor lock.
