-   -   MPI Fuel/Air Ratio (https://www.offshoreonly.com/forums/general-q/217836-mpi-fuel-air-ratio.html)
blr 10-01-2009 06:04 AM
MPI Fuel/Air Ratio
97 7.4 liter mpi
I have the above engine with stock exhaust and I would like to measure the fuel/air ratio, can someone explain how to accomplish this with the stock wet exhaust.?
Brian
jayhawk261 10-01-2009 02:32 PM
A/F ratio is measured using a wide band O2 sensor in the exhaust. To accomplish this, you would have to have a fitting installed into your exhaust manifold that penetrated through to the exhaust and sealed in the water jacket. It would be like a sleeved fitting into the exhaust stream. I have never heard of one being put into a factory exhaust before. CMI will put them in their tail pipes upon request for a fee. The sensor has to remain dry or it will not work.
jeffswav 10-01-2009 07:05 PM
Correct info, I have EMI exhaust with long risers and I had them weld in O2 bungs from the factory. Another method is to install a bung right at the exhaust port of one cylinder. This method eats sensors and is not very accurate.
