-   -   575sci Water Pressure port location (https://www.offshoreonly.com/forums/general-q/218550-575sci-water-pressure-port-location.html)
SonicBunny 10-14-2009 05:06 AM
hi -
We are looking for the location to installl the water pressure sensor... any ideas?
ciaoderhead 10-14-2009 06:57 AM
it's the drain on the Side of the block...my bad.
JaayTeee 10-14-2009 08:40 AM
I've seen them installed into one of the block drain
ports too.
If you were to do that, I'd put a tee fitting on it,
so you could still retain the blue plug drain fitting.
SonicBunny 10-14-2009 08:55 AM
Yeah, we discussed the block drain option... the only issue there is blockage from sand and other debris... The engines have super chillers too... not sure if that limits the space on the back side....
1 MAIDEN AMERICA 10-15-2009 09:48 PM
My H2O PSI is taken off the L side of the block. It's never had an issue. If the gauge gets plugged with sand its time to clean the block. An extra warning device.
