-   -   Doug Herbert Heads ??? (https://www.offshoreonly.com/forums/general-q/218798-doug-herbert-heads.html)
racn70 05-12-2011 12:01 PM
Originally Posted by racn70 (Post 3400345)
I have a set of the herbert 320cc heads on my 454 jet boat. the only issue i had was the guide plates, the rockers would not line up to the valves,they sent me dart adj. guide plate at no charge. everything else is working great. they are pro comp castings. there in house machine shop does the machining and assembles. I bought them as an up grade over my factory steel heads. I would buy another set for a budget build.
the doug herbert heads may not be for everyone but for my applacation they work very well. as far the casting goes, they are very nice. I was suprised myself. ive seen some sets from edelebrock and they were down right UGLY. as far as the flow goes, i was just looking for something better the the stock steel heads. I had mine flow checked and they are way better then stock. I run AFR on my race cars so I do know the difference. but the herbert heads are ok for mild builds.
