how many of you are using locked distributors on your motors ? >
Old 10-20-2009 | 10:35 AM
Default how many of you are using locked distributors on your motors ?
debating whether or not I should lock the timing on the dist while I have the gear off before I put the motor back together
are any of you guys locking the timing on your boat motors ?
550 hp 454 carb motor
with MSD dist
thanks
cbellamore is offline
Old 10-20-2009 | 11:53 AM
My MSD mechanical distributor is locked, but we are using the Crane ignition box that has advance curve options.
BenPerfected is offline
Old 10-20-2009 | 12:10 PM
boatman22's Avatar
Same here..MSD locked using a Crane Box.. 572's 650HP
boatman22 is offline
Old 10-20-2009 | 01:03 PM
I have been running a locked out MSD distributor with a MSD box at 34degrees. I have had good luck with it, my boat idles better and has less soot on the transom. I just built a new motor and put the mechanical advance back in, the only reason I did that is I have heard that at midrange cruise speed there is too much timing and may get detonation. I would rather go back to the locked out distributor, I am just paranoid about damaging new motor.
tx911 is offline
Old 10-20-2009 | 01:17 PM
I run locked..MSD distributor #34.. MSD Crank trigger and MSD digital 6 box with start retard turned on. pulling 20degrees out at startup.. MSD starter also..
JohnSchiavarelli is offline
Old 10-20-2009 | 03:52 PM
it will clean up the idle, the more aggresive the cam the better it works, but sometimes may start hard when hot with the timing locked....gear reduction starters help there...Rob
ezstriper is offline
Old 10-20-2009 | 04:16 PM
Mr Gadgets's Avatar
Charter Member #601
I ran locked out for years... 32* timing, bigger roller cam. Always worked good. MSD dist. Now I run a crank trigger with a home made box to control the timing..
Mr Gadgets is offline
Old 10-20-2009 | 06:52 PM
When I ran my timing locked at 34deg I broke the ring gear loose from the flywheel. I bought a retard box from msd with a signal stabilizer built in, retarded timing 20deg at startup and really helped the motor fire off easier. Also made it easier to set timing witht the stabilizer.
tx911 is offline
Old 10-20-2009 | 08:48 PM
Vinny P's Avatar
I hate the winter!!
I run mine locked @ 36*, no retard box. I run a Tilton starter, never any issues.
Vinny P is offline
Old 10-20-2009 | 09:48 PM
bob
Charter Member #40
I have also been running the locked advance. MSD Digital 6 has a function where it can automatically retard like 20 deg or so to start and stays retarded until 800 rpm. Works great! Also can take some of the total advance out .1 deg at time or in 1 deg increments, works above 2000 rpm. Makes running the timing locked in more manageable.
bob is offline
