pushrod length
changing my 502ho's to hp 500 carbs. i have all the stuff but am wondering if the standard pushrods will work? i found some info on BAM that the intake was 7.55 and exhaust 8.55. if this is right i cannot find pushrods in that length. anyone have any ideas thanks
Hp 500's are 8.550 and 7.550. :coolcowboy:
where can i get sets of these?? i've checked comp and their close but not exact
prostock
Manley push rods 8.550 - Part Number 25855-8 7.550 - Part Number 25818-8 You should get a push rod checker to be certain on these lenghts, but these part number correspond with what you are looking for! Dave |
Hey Chris, you were looking for 1" HVH Super Suckers too!!
As for the lifters, I'm not sure what would be the replacement for the Crane 16535-16. I'm sure someone knows. Dave |
Originally Posted by prostockcat
(Post 2979298)
We use Manley and we get most of our stuff from Doug Herbert or www.dougherbert.com I may have a used set that we took out of my Hp500 but I would have to check. |
thanks for the help i got morel lifters. i will double check that the 7.55 and 8.55 lengths work
Originally Posted by formula 382 sr-1
(Post 2979309)
This is for a Hyd Roller cam?
(Post 2979314)
Originally Posted by axapowell
(Post 2979303)
prostock
Manley push rods You should get a push rod checker to be certain on these lenghts, Dave |
stock gen 6 heads. there new motors. i did set my pushrod checker to 7.55 and 8.55 and they seem to be right on thanks again for all the help. i got the manleys coming
| All times are GMT -5. The time now is 10:20 PM. |
