-   -   Fogging 2006 496 ho??? (https://www.offshoreonly.com/forums/general-q/219657-fogging-2006-496-ho.html)
rockstar342 11-06-2009 01:29 PM
I have 2006 mag ho that do not have the usual fuel fliter/ water seperator. There is an in line fuel filter and in the position on the motor where a usual removable fuel filter would go is an elemental type filter that is accessed by removing a cover panel. When fogging, where is the oil put in to the system. This is a different fuel system comapred to my old 502's. Want to make sure i am doing this correctly.
tcuda499 11-06-2009 07:33 PM
really? I thought they all would have a screw on fuel filter??? New to me, sorry.
jjj 11-07-2009 07:09 AM
On my friend's 496ho, we unscrew the fuel feed fitting and screw in another connected to some clear tubing going into a gallon of gas mixed with a pint or more of 2 stroke oil & a few oz. of stabilizer. Run engine on ear muffs & flush. When the fuel mix is in system,(you will know when) drain water using blue pump. Restart with anti-freeze. Done
