-   -   Reverse Polarity? (https://www.offshoreonly.com/forums/general-q/219796-reverse-polarity.html)
86scarabIII 11-09-2009 10:56 AM
Reverse Polarity?
I put my boat away for winter and attempted to use an adapter for the shorepower so I can plug it into a wall outlet. I plugged it in and a warning light lit up on my switch panel that says "reverse polarity". I know what reverse polarity is, but I do not know in this situation would cause that light to come on. I never had a problem this year with my shorepower, so I'm assuming it has something to do with that adapter.
ninetym 11-09-2009 03:51 PM
Mine did that this year also. It turned out to be the adapter wasn't correctly put togrther. wasn't all the way tight. Check all your connections. Hope this helps
