-   -   500 EFI cam in carb engine (https://www.offshoreonly.com/forums/general-q/220099-500-efi-cam-carb-engine.html)
ezstriper 11-17-2009 06:15 AM
have a 9.5 to 1 509 going to a dart intake & 850, have full headers, can I use a 500 H/P EFI cam with this set-up ? thanks Rob
mike tkach 11-17-2009 06:44 AM
yes:coolcowboy:
Griff 11-17-2009 12:44 PM
Sure, it should work fine.
baja36ft 11-17-2009 02:55 PM
i would use the 525 efi cam....
ezstriper 11-17-2009 05:58 PM
ok, any body have one ? Thanks rob
Griff 11-18-2009 01:52 AM
525efi cam is a Crane 741 on a 114 lobe sep. Crane has limited cams available now so you would probably be better off to have rmbuilder custom grind one.
