-   -   Marine Alternators - screened? (https://www.offshoreonly.com/forums/general-q/22045-marine-alternators-screened.html)
kaamacat 04-11-2002 07:31 AM
Question. I'm replacing my alternators, and found a supplier on Ebay. Is the alternator supposed to be screened on front and back? His description to me in a e-mail says screened front, and sae back.:rolleyes:
David 04-11-2002 05:40 PM
I have the Delco single wire and it has screens front and back.
kaamacat 04-11-2002 06:24 PM
David. Thanks. I found somone on Ebay that can make me (2) new ones, and he mentioned a SAE back cover. (although his others look screened in the back).
Thanks.................Bob
RumRunner 04-12-2002 07:15 PM
Bob:
Have you spoken with anybody locally to see if they can make them for you ? I know there is an alternator/started rebuilder up here in Gainesville, although I have yet to use him.
Doug
kaamacat 04-12-2002 07:22 PM
Doug. I looked all over this area. There are (2) folks that do rebuilds around here (one in Alpharetta on rt9, and one up on rt53 near the Outlet Mall ) that I found, but, I can get two of these for $110 (55each) @ 55-60amp, which is all I want. (mine are original 37amp units, and are not screened, motorola units). One does not work............kinda explains why I needed to run on both batts last year. In fact, I dont ever think I remember my voltmeters above 12-13volts.
I found this on e-bay, and he sounds like a very good reference from what I can see. And, the cost from what I'm told for each rebuild will be 50-80each, so I'd rather go with these.
.......have you noticed that finding marine stuff around here sucks. (although you can always go to GaryGrimes for stuff when you need it).
Bob
RumRunner 04-13-2002 09:47 AM
You can find stuff, just not when you need it. There's also Tim over at Pro Boat in woodstock, he's got a good supply of parts.
excaleagle42 04-15-2002 07:33 AM
i haven't tried one but there are GM rebuilt marine alternators in JC Whitney. 65 amp, one wire hook up, $89.95.
ForrestC 04-15-2002 05:07 PM
Also, you can buy the screen kits for Delco one-wire alternators from Aftermarket Discount Marine for about $15.00. The screen kit is not listed on their web site, but just give them a call. They got 'em. You local alternator rebuilder will have one-wire internal voltage regulators for about $12.00 each. With these two items you can convert a remanufactured Delco automotive unit available from your Discount Auto Parts to a USCG approved marine unit for cheap!
