Tell Tale, water line/side dump? (so you know its getting water)
coming out of a jet boat my self..i understand your need to look over your shoulder.if you dont see water peeing on a jet boat ..well it means another teardown.last outting in my ls2000.burnt pistons in both motors.......
thats why i got the baja
There must be a way to just do a small line like a yamaha jet boat and not use ton much water so exhaust doesnt starve.
Usually the boats you see with the water pumping out the side are using a pressure valve and just dumping excess pressure while running. I've seen boats with dry pipes dumping water as well, but that was out the transom.
The only boat I've ever seen dumping water at idle with wet pipes had 1075's which I think have a multi-stage fresh water pump, not sure if it has something to do with the water pump on that motor or not. Would like to find out tho...
