-   -   Factory rods BBC (https://www.offshoreonly.com/forums/general-q/220840-factory-rods-bbc.html)
endeavour32 12-03-2009 12:12 PM
Factory rods BBC
I'm getting closer to assembling my 427 bbc. I have a concern about the rods that I have. They are factory BBC truck rods with ARP bolts. I'm going to be spinning this at 6100 rpms. The longest I may have the boat at this RPM is going to be for no longer than 3 minutes. Are these rods good enough for this or should I really go for something stronger and lighter like a manley h rod? The crank is a forged GM crank and the pistons are Forged Speed Pros. Money is a factor so if I don't need to replace these I'd like to use them. But on the same hand I don't want to be cheap and destroy the engine.
FIXX 12-03-2009 12:56 PM
Which rods are they? is their a dimple on them? what size are the rod bolts,3/8 or 7/16?
endeavour32 12-03-2009 02:49 PM
There is no dimple. These are the "thumb" rods that are used in trucks. They are ARP 3/8 bolts. I want to play it safe on this part but on the same hand I don't want to waste money if what I have is fine.
ballon78 12-03-2009 05:27 PM
You need the Dimple forged rods with 7/16 ARP bolts. or a set of aftermarket ones with 7/16 bolts
Sledge Hammer 12-03-2009 05:31 PM
I would be hard pressed to use those stock truck rods for 3 minutes at 6,100 RPM's. Then again, 3 minutes seems like a long time for most anything. You will always worry about them. I would change them out and be safe. If they go at 6,100 RPMs it will be a lot more expensive.
endeavour32 12-03-2009 05:37 PM
I don't think the dimple are much better. I know I've read that you can push them up to 7K but that for seconds. Three minutes is a long time at 6100, i do agree with that. What do you guys suggest? You have to remember a 427 spinning at 6100 is WAY different that spinning a 496 at 5500. 427's like to rev, but on the same hand I want to build this right the first time.
jeffswav 12-03-2009 05:52 PM
Get the forged HBeam rods.
mike tkach 12-03-2009 05:57 PM
:daz:
3/8 rod at 6100 equals KABOOM.7/16 is a must,if you plan on 500 hp or more,buy some h beam rods.as they say SEE
ME KNOW OR PAY ME LATER.
endeavour32 12-03-2009 06:42 PM
Ok so ditch the rods. Are the Manleys over kill? They're rated for 8000 rpms and 900 hp. I'm planning on 550 and 6100 rpms. Any suggestions?
fastdonzi 12-03-2009 06:54 PM
You can never have overkill on rods or crank. Don't skimp and get Eagle H Beams--> They will stick through the block just like a stock rod if not easier. my bilge pump pumped more oil than it did water when we used Eagles rods, and the sound of a rod breaking at 5500+ rpm is interesting, and expensive, get the good sh*t, it'll last through several motors.
