What oil pan to use?
What brand oil pans do you guys like to use?
I'm looking for recommendation for marine application, 540 CI with Dart block. Thank you |
I assume you have 1 piece RR. main seal.
Here is what I used on my 540's http://www.cantonracingproducts.com/...ion&key=18-362 I also installed these so no more dry starts: http://www.cantonracingproducts.com/...ion&key=24-016 Smitty |
Originally Posted by Dock Holiday
(Post 3000725)
I'm looking for recommendation for marine application, 540 CI with Dart block. Thank you I have a few of the Keith Eickert cast aluminum pans. New they were over a grand each. think you can get them around $700 each now. If you like I will let two of them go for $400 each. They are either 12 or 14 quart,.......can't remember off hand. Jon |
Originally Posted by Smitty
(Post 3000728)
Here is what I used on my 540's http://www.cantonracingproducts.com/...ion&key=18-362 I also installed these so no more dry starts: http://www.cantonracingproducts.com/...ion&key=24-016 Smitty Dart uses the 2pc rear main seal. Thanks Mark |
Mark
Canton also makes pans for the 2 piece rr main seal. They have all kinds of pans. Are you looking for steel or aluminum. I went with steel to save $$$$$. Dave |
I use the Canton 18-364 - BBC REAR SUMP MARINE POWER PAN (18-364)
A little more money but it a nice pan. Kris Vogt |
Originally Posted by cougarman
(Post 3000743)
New they were over a grand each. think you can get them around $700 each now. If you like I will let two of them go for $400 each. They are either 12 or 14 quart,.......can't remember off hand. Jon I am interested in those. Do you have any pictures or other information on them? Thanks Mark |
Mark
Make sure you will have enough clearance under those KE pans. The stringers in our boats are close to the bottom of the motors. Smitty |
Canton here
