-   -   500efi throttle body (https://www.offshoreonly.com/forums/general-q/221682-500efi-throttle-body.html)
Irishtornado 12-22-2009 06:11 PM
Does anyone know the cfm of the stock throttlebody and is there any direct replacements other than AS&M?
Raylar 12-23-2009 01:44 AM
My guess would be that the stock HP500efi throttle body is about a 800-900 cfm throttle body. The single monoblade throttlebody that comes on the HP525efi is suppossedly a 1200 cfm unit. The bolt patterns and linkage arranigements are different for both, but you have a few choices. You could get the upper plenum off a HP525efi and mount it on your HP500efi with its monoblade larger throttle body or machine out the opening on your HP500efi top plenum and get an aftermarket monoblade unit like the ones Arizona Speed and Marine used to sell. Unless your engine has modifications like more cubes, bigger cam, or serious head work just adding a bigger throttle body is not going to add any recognizable power unless the engine has been modified to need a lot more air. Mercury Racing has not hindered any appreciable horsepower in these engines in original form.
Best Regards,
Ray @ Raylar
Linster 12-23-2009 05:58 AM
I took a 500efi 3 years ago, installed a 741 cam, new Dart Iron Eagle heads that were ported and milled .040. Installed a Cometic .027 gasket which got the compression from 8.75 to 9.25. I had the engine dyno by Precision Marine and it made 570 HP. That is a 100HP increase. That was with the Arizonia Speed Throttle body. While on the Dyno, the 500 Efi blade was installed and it lost 12HP. On a stock engine probally would not made 10HP. Keep in mind it takes 20HP to get 1 MPH. 1 MPH is not noticable.
Irishtornado 12-23-2009 02:01 PM
Ray and Linster thanks for the replies I'm planning for next winters projects which will include heads,cam and computer reflash at that point I'm guessing my plenum and throttle body will be my next obstacle. Just planning ahead to see what options I have out there.
H2Xmark 12-23-2009 08:10 PM
call tyler crocket , he has been working on a new top plenum and throttle body, early dyno numbers were a big improvement
tcuda499 12-23-2009 08:17 PM
nice job! Isn't a 500efi 470 to the prop shaft? so it might be alittle more at the crank.
jwurl 12-23-2009 08:35 PM
I have Tyler Crockets set-up. It mounts the throttle body on the top of the intake. It is supposed to make 35-40 HP over stock. My engine will go on the Dyno in a couple weeks. I will let you know the HP numbers. Tylers set-up is $1000.00 with your old intake top returned as a core. jeff Wurl
H2Xmark 12-24-2009 08:32 PM
Wow, a grand sounds like a deal, does he recal the ecm for that price also? that would be a awesome package
jwurl 12-24-2009 08:47 PM
That price is just the throttle body,exchanging your top plate, and a couple of linkage pieces. Flashing your ECM is extra. I have some pics of mine sitting here, but cannot load pictures to this site. There is video of it on youtube. Just type throttlebody video in the youtube search box. Jeff Wurl
dookie 12-25-2009 02:33 PM
I would definately like to hear more about this setup , i have two 500 efis ,sitting there ready to install , and was digging through this section to see if there were any worthwhile upgrades (bolt on) worth doing..... this one definately sounds like a good one.
jwurl 01-19-2010 07:29 PM
I finally got the dyno results from my 500EFI with the Tyler Crockett Throttle Body Intake Mod. The engine is a 500 EFI bored and stroked to a 540, Bob Madera custom cam, AFR 305 aluminum heads, Aeromotive 1000 fuel pump, 55LB injectors , ect... The engine made 693 HP at 6000rpm. Torque is 690 at 4200. I will post more when I get the final dyno sheet. Jeff Wurl
TylerCrockett 01-25-2010 08:43 PM
It must be breathing to make power to 6000 RPM :D
offshoredrillin 01-26-2010 07:14 AM
exactly, the hp limiting factor on the 500's and 525s is the manifold itself, they are great for peak low end torque, but even with the larger mono blade throttle body they run out at about 5400 rpm. my 500's have afr 325 heads, cam, throttle body,injectors and comp redone, I'm at 625hp/670tq... I think the most anyone has gotten with this setup is around 630-640 without making it a 540. mine are stock bores.
