K-plane position
I have a 29' Warlock with K-planes. In the fully retracted position the left one is higher than the other. I want to adjust them so they are equal.
How high should they be in the fully retracted position? How do you level out the indicator? Thanks......... |
K-planes
In the fully retacted position the actual planes should be equal. Put the all the way up and go to the back of the boat and look at each piston, they should be in the exact same position. To adjust the indicators adjust the cable ends, fist at the plan, second at the indicator
| All times are GMT -5. The time now is 03:27 PM. |
