-   -   454 magnum exhaust (https://www.offshoreonly.com/forums/general-q/221914-454-magnum-exhaust.html)
sr1720 12-28-2009 08:19 PM
454 magnum exhaust
I have a 89 formula sr1 311 with stock exhaust. It has a 3" spacer between the manifold and riser. Would like to install Gill manifolds with a stainless riser. Is there a off the shelf riser that will work or do I need to custom order ?
Rockfish71 12-28-2009 08:46 PM
Buy a set of eddie marine they are really nice system.
http://www.eddiemarine.com/store/car...l&p=13073&c=63
DiamondPerformance 12-28-2009 09:14 PM
We have good deals on EMI Exhaust this month.
Let us know.
sr1720 12-29-2009 10:53 PM
Let us know.
Does EMI seperate the exhaust ports like Gill's do ?
Will I need to order a custom riser ?
With the riser coming a lot closer to the tail pipe than the factory junk there isn't a lot of room to flex that 4" hose.
DiamondPerformance 12-30-2009 07:57 AM
1 Attachment(s)
Yes, EMI seperates the exhaust ports. No custom riser needed, 3" Taller riser to replace Merc manifolds using a 3" Riser spacer block.
