-   -   Shift bracket wire question. (https://www.offshoreonly.com/forums/general-q/222074-shift-bracket-wire-question.html)
89 Baja 250 12-31-2009 10:28 PM
I'm still working on wires in engine compartment. Found what most of them are for. Just these 2 sets of wires left. Large orange and black,and orange red and brown zip tied together. Might they be the shift bracket wires?http://i24.photobucket.com/albums/c3...Picture623.jpghttp://i24.photobucket.com/albums/c3...1202091212.jpg
ittledoo 01-01-2010 08:54 AM
On my 265 the large ORG and BLK go to the hatch actuator. And the RED,ORG,and BRN go to the Mercathode.
Everything else looks very similar to mine.
hoozeyurdaddy 01-01-2010 09:05 AM
red,orange.brown are mercathode. orange and black may be hatch or power for K planes, could be some kind of setup for charging sys. try to trace them to where they go.
89 Baja 250 01-01-2010 10:13 AM
Mercathode
Thanks guys. Is the Mercathode needed? I am running in fresh water only.Is it an expensive system?
ittledoo 01-01-2010 10:15 AM
More guys on here will know the details, but the I've been told that the Mercathode is definitely needed!
picklenjim 01-01-2010 03:59 PM
Is the boat left in the water all the time or trailered? If it's always trailered out I wouldn't worry about it.
picklenjim 01-01-2010 04:05 PM
It's a system that protects your drive against corrosion.It consist of 2 "pucks" mounted on the transom,one on each side of the drive which are wired to a control box. They create a field that protects the drive. If it says Mercury on it you know it's expensive!! If your boat is not in the water 24/7 I wouldn't worry about it.
tms1155 01-01-2010 04:33 PM
While your in there get rid of those wire connectors and use heat shrink connectors. Those will corrode and cause problems.
89 Baja 250 01-01-2010 05:07 PM
I don't keep it in the water.On trailer. Thanks. I will remove the but connectors.
US1 Fountain 01-01-2010 06:12 PM
Go to Autozone and buy a qt of fiberglass resin and seal the holes that go thru the stringers for draining if they are just drilled with no protection. From looking at the pic, it appears to be raw exposed wood.
ROTAX454 01-01-2010 07:05 PM
Get rid of that ugly blue butt connector. The absolute worst way to physically connect two wires. No control over the crimp height on that type of connector.
1) non insulated butt connector
2) "light" crimp both wire ends with your stripped wire conductors (core)
3) solder both ends - no cold solder joints either
4) apply (this is done before you crimp your connector ends) a dual wall shrink tube. Heat and shrink into place
5) Done. You have now the best budget boater electrical connection for your marine application
89 Baja 250 01-01-2010 09:36 PM
Thanks I will sure check that. I just got the boat.Still cleaning and checking stuff.http://i24.photobucket.com/albums/c3...1205091625.jpg
bajabob 01-02-2010 09:25 AM
ware do you boat???
89 Baja 250 01-02-2010 10:44 AM
Originally Posted by bajabob (Post 3016153)
ware do you boat???
Delaware river. Mostly between Paulsboro New Jersey to Betsy Ross Bridge. At Penns Landing in Philadelphia there are a few good places to dock and grab a bite to eat.
