-   -   Water hose connection help (serpentine) 454 / 502 mag (https://www.offshoreonly.com/forums/general-q/222425-water-hose-connection-help-serpentine-454-502-mag.html)
22 DAYTONA 01-08-2010 01:53 PM
Can some one look at their engine or service manual and tell me if the fresh water hose from the drive connects to the top nipple on the sea pump or the bottom.
Thanks in advance Mitch
Advantage 575 01-08-2010 01:55 PM
it's on the top on my BAJA. To oil cooler and engine on the bottom.
fbc25el 01-08-2010 02:55 PM
The hose from the drive goes to the bottom of the pump. The top pushes water to the engine.
22 DAYTONA 01-11-2010 10:16 AM
That is the way I have mine hooked up, but now it sounds like the one on the Baja is coming from the drive to the top of the pump. Anyone have the install manual on the 2001 502mag or 454mag?
This was a picture from the dyno. When I looked at it magnified, it looked like the water in was hooked to the bottom. The hosed were not connected when I got it.
http://www.performanceboats.com/html...G_5490_NEW.jpg
PAST DUE 01-11-2010 07:27 PM
look at the back of the pump it will tell you which one is outlet for the corresponding direction of rotation.
Boat Tech 01-11-2010 08:01 PM
Also when you go to start the engine just have your hand on the impeller housing, If it starts getting warm you have the hoses hooked up wrong, If it stays cool then you are ok, You will know within 15 seconds if you got it right or not by feeling it.
mike tkach 01-11-2010 09:02 PM
on mine the lower hose comes from the drive:coolcowboy:
minxguy 01-12-2010 06:14 AM
Heavy walled hose goes on the suction side of the pump.
flexible hose output side.
Ken
22 DAYTONA 01-12-2010 09:48 AM
Thanks fellas.
