copper oil tubing lines ???
Has anyone heard of running stainless or copper tubing for oil line with compressioin fittings. I need to replumb the entire oil system and don't what to use the push on connectors. Any reccomendations. Jp
Merc used SS for part of ther lines on my 454. Don't see why it would be a problem until you have to work on something in the bilge and lean or step or fall on it and it bends or breaks. Personally I like having the flexibilty of hose.
I have used SS before. I would not recommend copper....to soft and its to susceptable to corrosion. Not to mention looks. I wouldn't use the SS again. It's to hard to work, no flexibility(lines must fit perfectly), and like BUB said, it can easily get damaged.
There are so many hose options to choose from today. You can spend a bunch on nylon braided or do it inexpensively in rubber with brass fittings. Good luck. Eddie |
Totally Agree!
I tried plumbing in an oil cooler with all SS tube but wound up having to put flexible sections on the ends because the motor and boat movement stressed the seals / connections causing leaks. I'd never try that again, simply not worth the trouble when compared to SS braided line. I've ditched all the tube now and run all SS Braided, much quicker and easier to work on and around! |
Originally Posted by Ghostrider
(Post 3021360)
Totally Agree!
copper is way to soft and would crack from vibrations, pounding etc....use braided...
| All times are GMT -5. The time now is 06:45 PM. |
