TRS Trim Sensors
Just wondering where is a good place to buy TRS trim sensors. The best price I have found so far is $85 for the sensor and limit switch (for both sides of the drive) shipped to my door. That seems fair to me, but I wanted to make sure that there isn't a site on here that everyone uses or anywhere to get them cheaper.
Don't think your going to find it much cheaper. Here's one from a place I have delt with and have pretty good service. Don't know if it would be any cheaper though once you add on shipping.
http://www.perfprotech.com/store/pro...A-2,24554.aspx |
Would these fix my issue where sometimes my drives get out of sync w/ each other when raising or lowering? A couple of times i have had to keep working the switch to where the indicators finally showed they were even.
Originally Posted by picklenjim
(Post 3022226)
Originally Posted by BDiggity
(Post 3022294)
Your issue sounds more like a worn out ram on the slower operating drive, or perhaps an issue with the way the plumbing is rigged that is causing one drive to operate slower than the other. I know it is annoying (mine aren't perfectly matched either), but I just remember which drive is slower and I don't hold the other switch down all the way when I'm adjusting trim. To me that seems to make a lot more sense than getting frustrated chasing the problem, rebuilding rams, building new lines, etc. |
(Post 3022294)
I have a few of these trim sensors laying around that are new. I have never had any luck with the accuracy of those things either. I use to locktite the hinge bolts also. At times they will move one way or the other throwing off the sensors big time. I always end up running by the seat of my pants. Not always the right way though. I am going to convert to the mechanical ones.
Originally Posted by getrdunn
(Post 3022688)
If you want to off a pair of these for less than I'm going to pay for them, let me know. The main reason I need a set is because my limit switches are toast, and i now have to use the trailer setting to trim the drives. |
| All times are GMT -5. The time now is 09:27 AM. |
