-   -   What fuel pump? (https://www.offshoreonly.com/forums/general-q/222855-what-fuel-pump.html)
Sick Stinger 01-16-2010 09:13 AM
What fuel pump?
I have an odd set up with a mech. and electric pump. Then elec. feeds the mech. and goes from there. What is the best pump to run 750 and have some left over rather not run the pump to its bitter end. Is there a mech. that will do it? Any one using race pumps or electric only way to go so you can wire it to cut out for oil pressure loss. Something like an A1000? How many GPH do i need
thanks
-Mike
Rookie 01-16-2010 12:46 PM
I had the same setup as you. Mechanical on my seapump feeding my electric Holleys. I removed the mechanical fuel pump because of failures. Gas diluting oil. And after 2 Holley electric fuel pumps failures I went to Mallory Marine 140's. I am at 600hp. I mounted them LOW in my bilge. Electric fuel pumps are designed to push fuel not draw fuel. They work great. I got mine off e-bay for under $100
http://www.jegs.com/i/Mallory/650/41...oductId=747713
I like the electric with the relays and tied into the oil system.
picklenjim 01-16-2010 01:18 PM
Here is a diagram from Teague Marine Site "Tech Tips"
http://teaguecustommarine.com//store...l_manifold.pdf
brian41 01-16-2010 01:19 PM
Buy the Areomotive 11108 marine pump and dont look back.................forget about the Mallory's and the Holley's
FORCEINU 01-16-2010 01:33 PM
Claysmith Fuel pump !!
no need for electrical pump only $125.00
1300 HP Fuel Pump
Clay Smith Engineering, home of the Original 6 valve pump, often copied but never equalled. A custom fuel pump to solve fuel supply problems for your R.V., performance or racing engines. You no longer need costly dual pumps to do the job one Clay Smith Power Pumper can easily do better.
Manufactured to stringent specifications by Clay Smith, this pump surpasses any known mechanical fuel pump on the market today for efficiency and reliability. Each Clay Smith Power Pumper is built fromexclusively designed components and is engineered to provide superior performance and unbeatable durability.
These pumps will supply 14 -16 PSI fuel pressure and pump 140 GPH (Gallons Per Hour), freeflow, through their specially designed 6-valve body. This massive flow will easily handle even the largest size Dominator carburetors, on gas or alcohol.
*And, according to dyno figures, it takes approximately 10 gallons of gas per 100 HP per hour, the Clay Smith Power Pumper will theoretically handle up to 1300 HP on gas or 1150 HP on alcohol!
Clay Smith Custom Fuel Pumps are available for virtually all popular engines, including; Chevy Big Block, Chevy Small Block, Mopar "B" Block, Chrysler 426 Hemi, all Small Block Fords
EATSLEEPBOAT 01-16-2010 01:43 PM
+1 Aeromotive all the way :drink:
US1 Fountain 01-16-2010 03:46 PM
The stock Merc mechanical pump will support 2 ) 750 holleys on a 420 blower with no problem.
I used the stock one also on my blown 502 with a 1050 Dominator. Pressure never flinched.
BenPerfected 01-16-2010 05:15 PM
The CV Products mechanical pump supports 750+ HP at less than 7.5 LBS and more than 6 lbs ay WOT without a regulator. Order it with the green spring. It is a little pricey, but the last pump you will need to buy.
MER Performance 01-16-2010 09:16 PM
CV Products, Thomasville, NC.
Call Allen, Here's what I use. Billet mechanical pump either block mount or sea waterpump mount. 100% rebuild. They have different psi= volume. I have never had to back up a mech. pump with a electric. expect to spend about 400
