-   -   Head Gaskets (https://www.offshoreonly.com/forums/general-q/222892-head-gaskets.html)
OhioRiverCigarett 01-16-2010 10:34 PM
Head Gaskets
What are the thoughts on the best head gaskets brand and material.
I am building ~500 horsepower 454's. They are 0.030 over. What are the thoughts on copper? What size gasket diameter should I uses for a 4.280 bore?
mike tkach 01-16-2010 11:45 PM
i use the fel pro marine gasgets on every bbc marine engine from stock to supercharged.gasget bore needs to be at least .010 larger than cylinder bore.i only use copper on all out dragrace engines with reciever groove &o rings.
Vinny P 01-17-2010 05:19 AM
Personally, I only use Cometic gaskets.
brian41 01-17-2010 07:59 AM
I use both Felpro and Cometic but for your application Felpro marine gaskets are all you need.
ezstriper 01-17-2010 08:00 AM
I would not use copper, my race engines use them and they seep water, not needed in that felpro's work fine...
Smitty 01-17-2010 09:03 AM
Fel-Pro MLS gaskts
PatriYacht 01-17-2010 09:41 AM
Felpro blue teflon composite gaskets are all you need for this application. Anything more is a waste of money. Copper is a headache that only super high boost requires.
Young Performance 01-17-2010 12:21 PM
Patiryacht hit the nail on the head on every point. I love the Cometics, but they are just not needed in your application. The correct Fel Pro gasket for your application will have a 4.320 bore size, I believe.
Eddie
formula 382 sr-1 01-17-2010 12:23 PM
+1:coolcowboy:
Rookie 01-17-2010 07:17 PM
Fel Pro 17042 for your application.
http://www.amazon.com/Fel-Pro-17042-.../dp/B000CEMIDQ
