-   -   Alpha upper (https://www.offshoreonly.com/forums/general-q/22296-alpha-upper.html)
Mother 04-15-2002 04:46 PM
Alpha upper
I actually have 2 questions:
1) how do you split the alpha apart? I've gotten the 3 nuts on the 'gimbal' side of the drive, and the two on the bottom of the ventilation plate, what now?
2) What constitutes a usuable core on the upper case? When my gear went the case got gauged around the the outside of the driven gear, is it now trash? I can't see how that section of the case would affect anything except peraps oil splashing, and then you could just putty it up and hone it??
Thanks in advance,
--Adam
P.S. As I had feared, the #%^@! that sold me the boat put a 1.5 (20/22) drive on the boat... Behind a damn 454.. WTF! That helps explain the brief drive life...
ForrestC 04-15-2002 04:50 PM
Now remove the zinc trim tab with an allen wrench and you will find another allen-head bolt under the tab. It's got to come out too.
Mother 04-15-2002 05:02 PM
DOH!
Thanks Forrest
--Adam
